Using C3D 2016, the Layer Unisolate button (command LAYUNISO) located on the express toolbar doesn't "work" correctly. It does not restore your drawing layers to the previous state. The firm where I work uses tabs inside of the drawing (which I don't prefer) and when you go to other tabs for such viewports as DEMO, or your LAYOUT tab the entire viewport is completely changed and did not restore. The thing is, I may also not even be working within that particular viewport. This is causing a great deal of problems (and valuable time lost) especially if I have a drawing that might have many viewports in them. I'll then have to go back into each drawing and set up the viewport again, layers on/off, frozen, etc. I assume that this is a cad error of some sort and maybe someone knows what is causing this. A search of LAYUNISO didn't offer any results. Help would be greatly appreciated.
Thanks.
