Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Layer Translator on multiples drawing files at one time?
sbrownYFRM4
sbrownYFRM4
Good afternoon, can layer translator be done on multiples drawing files at one time?  If not is there a third-party software that will layer translate several drawings at on time?  If not we will have to open each drawing to get layers on the right lineweights, layer names and colors  Thanks in advance for your time.
pendean
Community Legend
Community Legend
You will need to customize: LISP or VB is the way to go, here are those dedicated forums to help you out https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
АлексЮстасу
You can try to do it with a script.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
lynn_zhang
Hello @sbrownYFRM4 , thanks for posting!
I've edited the subject title of your thread so it better describes your problem. This makes it easier for other community users to find the post when they search with key words.
Did the response from our experts above help answer your questions? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
Joe-Bouza
I have had good succes by setting up a macro in the action recorder and adding (command "macroname") to my acaddoc.lsp file and then run a batch publish to a bit bucket.
works great for layer state and other macro task.
Joe Bouza
