& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
When I open the Layer States Manager, I get the useless and persistent box outlined in the appended image. It obscures my search. I want it killed.
How may I prevent this box from blotting out my list?
Many thanks.
That's a TOOLTIP.
Set value for TOOLTIPS = 0 to turn it off.
This will turn off all tooltips, so you may want to turn it back on when done w/ Layerstates.
@Anonymous wrote:
That's a TOOLTIP.
Try putting this in your ACADDOC.lsp file.
It will setup the "STARTUP" function (that runs everytime you open/create a dwg file). It will UNDEFINE the layerstate command and then create NEW layerstate command that runs in it's place.
The new version will turn off TOOLTIPS, then run the original layerstate command and then restore it to its previous setting. This way your existing menus will still work. 🙂
(defun-q lstate() (undefine "layerstate") (defun c:layerstate(/ tips) (setq tips (getvar "tooltips")) (setvar "tooltips" 0) (command "_.layerstate") (setvar "tooltips" tips) ) )(setq S::STARTUP (append S::STARTUP lstate))
Don Ireland
Engineering Design Technician
Now that's thinking through the box.
Yes, turning off the tooltips worked, and many thanks.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
