Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Label Text Size Issues
dave.mahoney
dave.mahoney
When I use an expression to control my label text size it stays constant and does not change as the drawing scale changes.
My expression is the following.
2.00/{Drawing Scale Conversion}
The following images show the pipe size, length slope and inverts. The pipe siz and the inverts have had their text size change  using the expression while the length and slope have text sizes of 2. They all should be the same but the expression is not working.
annotation 1:1000
annotation 1:1500
Annotation 1:500
I am using Civil 3d 2014 SP2
Any help would be appreciated.
Regards
Dave
Replies (7)
kmfuhrman
It has to do with the Annotation...select the label, and on the Annotate Ribbon, click Add Current Scale on the Annotation Scaling panel. Add the scales you need to the label. As you change scales, the label should change appropriately. Make sure you are using an Annotative text style in your label.
Kimberly Fuhrman, LEED AP BD+C
Freelance Architectural Technologist
dave.mahoney
These are Civil 3D Pipe labels not Autocad labels.
Civil 3D labels do not require annotation to be added to them as text size is controled in the label or using an expression.
I have not had any issues until recently using my expression.
rkmcswain
If you reset the label to it's original location (i.e.: non dragged state), do the sizes look okay?
dave.mahoney
Only the 1:1000 scale.  All other scales have the same issue.
annotation 1:1000
annotation 1:500
rkmcswain
Apologies if these are basic questions........
Is that a single component or more than one component?
If the latter, do they all have the same expression entered for their size?
Lastly, is your "Dragged State" display set to "As Composed"?
dave.mahoney
It is a multiple component label which adds the direction for the start and end of the pipe.  The length, slope and description are set to 2.00mm whereas the inverts are set to 2/{Drawing Scale Conversion}. Both of which should display the same size.  If I add the expression to the length, slope and description all components are the same and will not change according to the drawing scale. It's like the drawing conversion scale is not working.
I'll try a repair on Civil 3D or a reinstall. Hopefully that'll fix the issue.
dave.mahoney
The issue seems to be only with pipes.  All of my other labels work as expected. They change size when when the drawing/viewport scale changes.
