Label Stack
Label Stack
brian.strandberg
Advisor Advisor
Label Stack
brian.strandberg
I have to make a font change to a large # of my labels, and I see this issue in a few of my labels.
This is fairly easy to fix, but I would like to define these using the Stack / Unstack button so I can have that generate the horizontal line.  I also don't have trouble with labels created this way.
However I can't get that to work with a blank second line.  Anybody know a trick for this?  Link to the help section on this: Autodesk Civil 3D Help | To Add Stacked Characters to Label Styles | Autodesk
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
MMcCall402
Maybe use a space on the second line.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
user181
For the blank line try holding the ALT key and type 0160, it will leave a blank space as text.
brian.strandberg
Non-breaking space ALT 0160 was my first try after a normal space. That will produce this:
There isn't a tilde anywhere in my style, but in stacked context it displays the space (only a space, no other content) as a ~.  I tried regular space, non-breaking space, I even tried the U+2000 and other spaces. They all produce something like above.
I thought I would post here and see if somebody has a funky workaround for this.
ChrisRS
What font are you using?
Christopher Stevens
