Label elevation alignment
luiz.silvaNDFA2
luiz.silvaNDFA2
Does anyone know a way to insert a label at an offset alignment
and show the profile elevation at that point? This label has to be manually inserted in the desired location, a label set would not meet my demand.
huamani1277
 hola, buen día Tienes que agregar etiqueta de perfil al componente de etiquetas de alineamiento con (copiar y pegar) adjunto algunos imágenes
surafeltklt
use the procedure attached u have to create top surface if not make the reference text in step 5 profile instead of surface
1st go to annotate tab
2nd click on add labels
3rd from the feature drop down select alignment
4th  choose one of the label styles to edit
5th go to label style composer and in layout tab add reference text it should be surface since ur enquiry is elevation
 go to content edit the content to elevation
apply and use this style to label ur offset alignment
I am not god at describing things so I have attached a video sir
thank you
luiz.silvaNDFA2
@surafeltklt
It worked perfectly thank you very much.
