Civil 3D Forum
Label assembly with field automatically
7 REPLIES 7
Message 1 of 8
neilyj666
2433 Views, 7 Replies
Found a link to some code (http://c3dxtreme.blogspot.com/2010/12/automatically-label-those-road.html) to automatically place an Mtext field to label assemblies. It was written for C3D 2009/2010 but I can't get it to work for 2011 - any VBA gurus care to take a look to see if it will run (or not) on 2011
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
7 REPLIES 7
Message 2 of 8
Jeff_M
in reply to: neilyj666
Well, I was able to modify the file so it works in both 2009 & 2010. The same file should work in 2011, but I can't test it because I do not want to install the VBA enabler. I've made a few other minor changes as well, but since Justin is the one who posted this routine I feel I should ask him if he'd like to post the revised file or if he wouldn't mind me doing so here. I've sent him an email asking just this....
Jeff_M, also a frequent Swamper
Message 3 of 8
KirkNoonan
Wow, quick work gettingthat link killed!
Message 4 of 8
Jeff_M
in reply to: KirkNoonan
The link is exactly how it's posted on the blog. I think there's a problem there, not with someone "getting it killed". Smiley Happy Here's a link to the page it's on: C3DExtreme
Justin has granted permission for me to post the updates here.
Attached is a zip file with both a VBA and Lisp version of the code. Either should work in any version of C3D. There is a Readme with a little more info.
Message 5 of 8
neilyj666
Many thanks Jeff_M (and Justin) for the quick turnaround to this request - I've just tried the lisp version and it works perfectly
PS in the original link I posted, an extra bracket had crept in at the end so the link didn't work
Message 6 of 8
jmayo-EE
Thanks for the additional work of the lisp version. I've been coping mtext objects from assembly to assembly and editing the field. I'll give it a shot in a bit.
John Mayo
Message 7 of 8
onsionsi1
in reply to: Jeff_M
I tried to try VBA with Civil 3D 2012 and it didn't work
Thank you in advance.
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
Message 8 of 8
Jeff_M
in reply to: onsionsi1
A little more information would be helpful. "It didn't work" is not very descriptive. Were there any error messages or warnings? How did you load and run it? DId you try the lisp version?
I cannot test it in 2012 because I did not, nor plan to, install the VBA Enabler.
Rail Community
