Issue with the Structure Insertion Point (Built in Inventor)
diaa_maa
diaa_maa
How to fix the issue with the insertion point to get the attached point at the center of the structure.
I have created this structure in "inventor"
gregory109chavez
Community Visitor
Community Visitor
I have created this structure in "inventor" destiny mastercard
Hello, @diaa_maa
To adjust the insertion point in Autodesk Inventor, follow these steps:
Edit the Sketched Symbol:
If you’re dealing with a sketched symbol, you can change its insertion point.
An insertion point is essentially a workpoint within the sketch that serves as the insert point.
Here’s how:
Open the sketched symbol for editing.
Locate the existing insertion point (workpoint) and delete it.
Create a new workpoint using the sketch tools in the browser.
Set the new workpoint as the insertion point using the drop-down menu on the toolbar.
Use Geometric Constraints (Inventor 2022):
In Inventor 2022, you can apply geometric constraints to control points and curves.
To fix a point (such as the center of your structure):
Click the “Sketch” tab.
In the “Constrain” panel, choose “Fix” (for 2D sketches) or “Fix” (for 3D sketches).
Click on the desired curve, center point, midpoint, or point in your graphics window.
Right-click and choose “Done,” press Esc, or select another tool or command.
Remember to adapt these steps to your specific situation.
I hope this information is helpful to you.
Best Regard,
Gregory Chavez
