I created a site grading base file for a high school project in December 2017. The project is made with Civil 3d 2018. In my workflow, I find it best to create separate dwgs for grading and pipe networks and then reference and data shortcut the civil 3d objects to a base file and create layouts for the base file.
On this project, I used feature lines primarily as corridor baselines. My feature lines were created from objects (polylines) and either assigned elevation by matching the existing ground surface or by manually inputting elevation data or a combination of the two. Many elevation points were entered on many feature lines. I made three or four corridors and each had a number of baselines to ultimately create a site grading plan.
When I go to open the drawing now, I've noticed that some of the PIs and elevation points have changed to zero elevation. It appears seemingly random except for the fact that it is happening to only the feature lines that have been used as corridor baselines. The corridor and corridor surface are not affected by these zero points. However, if I go to edit the feature line and then rebuild the corridor I see the "holes" in the surface. At this point, I'm stuck with the surface that was originally generated from the feature line creations.
I'm attaching the dwg. Would love to hear anyone's feedback. Has anyone else experienced feature lines changing elevation without any input? How can this be resolved now? How can I manage the dwg so this doesn't happen?
Thanks.
