Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Issue with Corridor surface? *pics*
I'm not quite sure what's going on here...the corridor surface seems to be created just fine and I pasted the corridor surface to the EG surface without issues. But when I change the Visual Style from 2D Wireframe to something else like Shaded, the corridor displays these "gaps" on the ends. My corridor is fairly simple as it is just an open grass trench. The only surface I have created for the corridor is Datum. There is no depth as far as materials go, the Top is the same as Datum...
tcorey
What if you do an elevation or slope analysis with a single range?
In the surface style editor, be sure to change your model view so that is displays the analysis, not the triangles.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Hmm, I did this and nothing seems out of sorts... Is it a moot point or non-issue if nothing seems to be "wrong" in the drawing? I guess just the fact that it's there bugs me and I wanted to fix it. But maybe I'll try and ignore it?
cwr-pae
I have seen this in 2d solid hatch on flat but complex plines, some triangular part of the hatch doesn't show on properly. If you have the triangle side along the open edge of the gap its just that.
If the triangle edge isn't there try checking the add link as breakline box and/or the feature line for the daylight point.
