Announcements
Issue adding multiple DEM Files to Grid Surface
I'm trying to add 4 DEM files to a grid surface.  The specific area I need to analyze is at a common corner of the 4 dem files.   Whenever I add the second DEM file an error report will show up saying that duplicate points are ignored.  However, the second, third, and fourth DEM do not show up on the surface; only the first.  error report.PNG
I am using Civil 3d 2018.  Versjion 12.0.1386.0 AutoCAD Civil 3D 2018.2 Update.
Replies (8)
Mike.M.Carlson
Hi-
I would create separate DEM surfaces.  I think you will run into problems adding them into one surface.  Then I recommend creating a Data Shortcut for these 4 surfaces to a formal Data Shortcut Project folder where you can DREF these 4 surfaces into a fresh /clean dwg.  There you can create a composite surface (or shell surface) where you can "paste" these 4 surfaces together.  I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Professional
AutoCAD Professional
Pointdump
Caleb,
Mike's advice is excellent. An alternative would be to merge those 4 DEMs with the free <<<MicroDEM>>>, like <<<This Page Shows How>>>:MergeDEM_1.png
Some further speculative thinking:
A DEM is sort of a raster, and Raster Design is great for merging GeoTiffs. Would be interesting to try it out.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Rebecca_Yu
I'm running into the extract same problem. I tried exporting each DEM surface as a data shortcut, but when I bring them into a clean drawing to paste into a surface, I don't have the option to paste. Even though I'm selecting Grid, not Grid Volume surface as a type, it's still not an option. Is there another way to paste a DEM surface than the usual, selecting the surface in the Prospector, going into the Definition and right-clicking on Edits?
Mike.M.Carlson
Hi
Try to create a new surface, then paste in the DEM surface into that new surface, then past in additional surfaces in new surface.
Or DREF out the DEM surface from source file (keep DEM surface dwg just for DEM surface) and then import the DREF'd DEM surface into fresh dwg, then create new surface, paste in DEM surface into new surface, and paste other surfaces in from there.
I hope this helps.
Michael M. Carlson
CADD Manager
Rebecca_Yu
Hi Mike,
Thanks for the replay but unfortunately when I tried either method to paste in the DEM surfaces as you suggested, I kept getting an error message about being unable to paste. I don't think it liked trying to convert from DEM to TIN. I had to go back and recreate the surface from GeoTIFFs in order to get a combined surface that worked.
Rebecca
Drea_Mueller
I searched and found this post on the AKN.
https://knowledge.autodesk.com/support/civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/Civil...
Apparently you can't paste grid surfaces into a TIN surface and you don't have the option edit option of "paste surface" if instead, you try using a Grid surface as your overall surface. This is very disappointing.
bcperryM6TUV
Observer
Observer
While NOT ideal, you can create a TIN from multiple DEM files. Depending on what you are doing this might be OK. Also if you have large DEM files, you can use the simplify surface function on a TIN to help processor load. 🙂
Rebecca_Yu
Very disappointing. You would think there would be some sort of solution for that.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
