Civil 3D Forum
Is there an easy way to remove hatch behind text?
4 REPLIES 4
dsnyderGT3KW
2718 Views, 4 Replies
if i add text then hatch the area it creates a blank boundary around the text, but if i add the text after hatching it continues behind it.
currently i am just deleting the hatching then redoing it which sometimes causes problems. i looked thru previous posts about hatching but i may not know the correct term.
attached an image where the top text was added before hatching and the bottom was added after for reference .
thanks in advance for any advice
Tags (1)
4 REPLIES 4
AllenJessup
in reply to: dsnyderGT3KW
I think the most common solution would be to add a Background Mask to the text.
Allen Jessup
CAD Manager - Designer
user181
An option would be to select the hatch and then on the ribbon choose the "Select" option and the select the text.
tcorey
@dsnyderGT3KW
I looked at your screenshot, but both text objects appear the same. Neither is behind the hatch.
Nonetheless, I see what you're getting at. If the text is present when you create the hatch, it can become an island, where hatching does not appear. If I might project, your question is, "How do I add islands to a Hatch?" That would be most-convenient, over using textmask, but I don't know a way.
Through Visual LISP, you should be able to accomplish this using the Hatch object's InsertLoopAt method. At the moment, I am unable to find an example of its use. If anyone can provide.....
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
rl_jackson
I'm with @AllenJessup on this one, if you change scales using annotative text, that hatch boundary does not change. I've not used dtext since mtext became available, IMO it is a bain to Autocad (dtext that is) and I deal with Carlson overtop of C3D on a daily basis, which exclusively uses dumb text for smart things.
Rick Jackson
Survey CAD Technician VI
Rail Community
