Announcements
Is there a way to convert elevation datums?
dsnyderGT3KW
dsnyderGT3KW
I do surveying work in Florida most county's want elevations to be listed in NAVD 88, with the exception of 3-4 that want the elevations shown in NGVD 29, there is typically a 1.5' ~ difference between 29 and 88. Is there an easy civil3d way to convert all my elevations on a file?
Thank you for any info in advance.
Replies (10)
_Hathaway
If you haven't processed your drawing the easiest way is to edit the source data before it gets to the drawing.
If it's already in your drawing and you have an existing surface you can select it, then raise/lower surface by the desired elevation.  IMO this is dangerous but may be the easiest.
I am sure there or more ways, as there often is in Civil3d, but those are the first that come to mind.
In those situations we always edit the source data as it's much easier downstream.
AllenJessup
There's a new Coordinate Transformation Tool for 2022. It will do Horizontal and/or Vertical transformation.
Also
https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Civi...
Allen Jessup
CAD Manager - Designer
Jeew-m
I am not sure whether this helps.
But you can change the datum from the ribbon after selecting the required points.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
rl_jackson
While I was unaware of the new tool @AllenJessup refers too, I'll certainly be testing it very soon, as I too, adjust data in FL between 88 and 29 along with the super special City of Miami datum (tool probably won't help there). However, if you're using the Survey Database you can do the vertical transform from there right in the SDB. I use either a Corpscon calculation or local NGS to make my 1.5~ adjustment (preferred).
Edit: If your not using the Survey Database, you can select all points and there is a Datum adjustment option.
Rick Jackson
Survey CAD Technician VI
Pointdump
Daniel,
The new Transformation Tool mentioned by @AllenJessup looks promising, but I only see transformation to Geoid models. I wonder if you could add NAVD29 and NAVD88 to the list.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Pointdump
Daniel,
Clicking the Help on the lower-right corner, I read:
"Select a target Datum.
The datum options are determined by an International Service for the Geoid (ISG) file of Earth Gravitational Models (EGM) installed to C:\ProgramData\Autodesk\C3D <year>\enu\Geoid Models.
There are many different additional models listed at >>>ISG-International Service<<< for the Geoid. The list includes a list of public, private, and on demand models encompassing over 100 countries (and with multiple versions of each)."
But I don't see anywhere to download NAVD29 or NAVD88.
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
Daniel,
I think I found the grid files for conversion between NGVD29 and NAVD88 >>>Here<<<. Not sure yet how to add them to the Transformation Tool.
Dave
Dave Stoll
Las Vegas, Nevada
AllenJessup
@Pointdump wrote:
Daniel,
 That's a shame. I haven't tested it out myself.
I'm a fan of Corpscon as @rl_jackson mentioned. But it becomes complicated if you're dealing with anything other than points.
Allen Jessup
dsnyderGT3KW
i will have to check this out thank you for info
dsnyderGT3KW
I have in the past only used corps con to covert a section corner, never even thought to look into vertical data shift, thanks for info
