Is there a way to assign an elevation to a curved feature line at the second point while drawing?
aguirre2
aguirre2
I was wondering if while I am drawing a curved feature line if I could assign an elevation from a cogo point at the second point of the arc.
Currently, I draw the feature line then come back and insert a PI at the point with the point elevation.
Thanks.
AllenJessup
Draw the Featureline with the 3 points at elevation. Then use Fit Curve.
https://civilimmersion.typepad.com/civil_immersion/2017/05/editing-civil-3d-feature-line-geometry-us...
Allen Jessup
CAD Manager - Designer
aguirre2
Thanks, that is a command I probably should have utilized by now.
I still have to come back to the curve to select the points so I am not sure if I am saving any time but I will test it out.
AllenJessup
How are you doing it now? Fit Curve or drawing 2 continuing arcs are the only way I can think of.
Allen Jessup
aguirre2
I draw a feature line starting at the first cogo point then specify arc and select the second cogo point and then the end cogo point.
With this method I have to come back and insert a PI at the second cogo point so the curve elevation matches the second cogo point elevation.
AllenJessup
About the same. You could also insert an Elevation Point. But, again, that's a similar operation. I don't see any way to do in in one shot.
Allen Jessup
