Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Irrigation water canal/channel design
iamlatifullah
Message 1 of 1
iamlatifullah
Hello, There! How are you? I hope you are all doing well.
I am going to start designing Water Canals in Autodesk Civil 3D.
So, I was curious if I am able to design (not only model) a channel/canal crosssection in Autodesk Civil 3D based on the discharge available as the inflow and discharge required as outflow.
In case Civil 3D is only able of modeling an already designed cross-section, Is there any other Autodesk Software for designing Water Channels/Canals based on the required Discharge?
Engr. Latif Ullah
BIM Manager
Replies (0)
