Intersection between the two channels
Marielen_
Marielen_
Hello, I would like to make the intersection between the two channels, does anyone know how?canaleta.JPG
jroot
Assuming this has been created so far with a Corridor...  stop the corridor in the area of the intersection and model the blank area with Featurelines, adding them to the Corridor Surface.
jae.kwon
I would probably treat it as a road intersection.
Split region into two to leave a gap, and do a "curb return" in each corner.
lynn_zhang
Hello @Marielen_ ,
Just checking to see if your problem has been solved. Have you tried the suggestions from above and did any of them work? If yes, please click on the "Accept as Solution" button in their reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
