Intersection at Elevation 0
vitorweidner
Message 1 of 8
vitorweidner
Hello
I'm trying to make intersections in my project, but every time I generate the intersection it goes to elevation 0.
I have already created elevation points in plan and exported to the profile to ensure that the elevations are equal, but it is still not working.
Replies (7)
Message 2 of 8
tcorey
Did you create a Finished Grade Profile for the main road and the side road of the intersection and did you assign them correctly? Did you lock the side road station control point to the main road fg profile?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 8
vitorweidner
I just created the profile of the two streets I designed and kept the same elevation at the intersection point. I don't know how to lock the point in the profile, but they are at the same elevation.
Message 4 of 8
Udo_Huebner
Upload your drawing, then you will have the answers from experts quickly.
Gruß Udo Hübner (CAD-Huebner)
Message 5 of 8
vitorweidner
I would like to know how to solve this problem so that in the next projects I can avoid it.
https://drive.google.com/drive/folders/1ioiz1H-HkVcvmeAAGa04rPiohNLIieSo?usp=sharing
Message 6 of 8
Udo_Huebner
The elevation of the used Profiles "Intersection - (7) - SW - Quadrant - Profile" and "Intersection - (7) - NW - Quadrant - Profile" is 0.
Then corridor region RG - "Pista esquina - (37)" start from Elevation 0 to the assigned target elevation then.
Corridor - (6) > RG - Pista esquina - (37) > Intersection - (7) - SW - Quadrant - Profile
Message 7 of 8
vitorweidner
thank you very much, now it will work
Message 8 of 8
elijahosugaG7J92
Please see a video that addresses thee problem: https://youtu.be/_qoqQoPr1mg
