Civil 3D Forum
Intersection : Adding a 2nd intersection to a corridor - Missing regions
3 REPLIES 3
cyberflow
116 Views, 3 Replies
So i've been trying to create a 2nd intersection into my corridor and it doesn't create certain regions and i was wondering why.
Anyone has a clue ?
I know it's a bit vague for a question but i'm just asking if someone has experienced this and maybe knows the solution
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
3 REPLIES 3
MSchille-1994
in reply to: cyberflow
This is kind of hard to answer with not much known about your model.  I am going to assume you created intersection #2 the same way you created #1?  I assume you have separate Baselines in the corridor for the different intersection areas?  With your example you should have four different baselines for your two intersections, one for each intersection curve.
How I do it, each intersection has two alignments, one mainline road and one branch road.  I then create a Connected Alignment and Connected Profile for each intersection quadrant, this is where the four different baselines come from, one for each intersection quadrant.
Make sense so far?
Attitude, not Aptitude, Determines Altitude
Typically when regions do not show up, it is a targeting issue.  Have you tried creating the intersection by itself, not part of the parent road corridor?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Joe-Bouza
Are the assemblies correct for the targets assigned?
Joe Bouza
Rail Community
