Interpolate 3D polyline with different elevations
Ingrid91
Ingrid91
So I've received a file that is a mixture of 2D- and 3D-polylines. My task is to convert these into 3D-polylines with either a) using the elevation from the model or b) using a standard elevation with regards to the surface model.
The problem is that along the 3D-polylines there are vertices with elevation 0. I'm not sure how it was modeled but the end result is very jagged. It'd be easy to draw a 3D-polylines between the vertices with an elevation, but the lines don't go in a straight line in plan view.
Is there a way to get a 3D-polyline or a feature line to snap to the location of a 2D (elevation 0) vertex without gaining its elevation, and make it so that the rest of the height is interpolated?
As it is I've tried to: draw 3D-poly between to points. Made it into a feature line. Added PI to the feature line roughly corresponding in distance to where the vertices are located on the 2D/3D-poly. Turned SNAP on/off to find the vertex but not gain its elevation. It's doable, but it's not exact as I can't snap to the line and it feels time consuming.
See pictures below for clarification.
VincentSheehan
If I'm understanding, something like this?
The red line is a feature line at different elevations. The white line is a polyline at 0 elevation. I set the view to ISO. I add PIs to the feature line while snapping to the polyline.
(view in My Videos)
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Joe-Bouza
.XY in the osnap options may be what you want
Joe Bouza
brian.strandberg
OSNAPZ=1, when you snap to an object with OSNAPZ = 1, you will only get the XY point.  The Z will become the current ELEV (usually 0).
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Ingrid91
I've googled to try to find what you mean but don't see anything specific regarding .XY
Ingrid91
Unfortunately that won't help, as the elevation that I want the added vertices to receive is the interpolated one. So having it set to =0 means that it would take the 0 elevation, and having it set to =1 means that it would take the current ELEV which is also 0.
Ingrid91
Such a simple solution! Thank you for the clear video 🙂
