inserting a jpg with the mapiinsert command
Message 1 of 19
 I’m having trouble with simply inserting a jpg with the mapiinsert command...and not sure how to use the other files that download from the national map viewer. Thanks,
Edited by
Discussion_Admin
Replies (18)
Message 2 of 19
Pointdump
Mike,
Welcome to the Autodesk Forums!
You'll definitely want to start a new thread for your question.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 19
AllenJessup
You should have gotten a .JPW (JPEG World) file in the download. That file should be in the same folder as the .jpg prior to insertion. If you still have trouble. Post with details on what goes wrong with the insert and which tiles your downloading from national map.
Allen Jessup
CAD Manager - Designer
Message 4 of 19
mikeshick
I'm not sure what you mean by posting a new thread.  My thread is new 🙂  Please clarify.
Allen, regarding files downloaded, maybe I downloaded the wrong data, but here if a view of what I received:
http://gofile.me/2Lpxp/JOGswTKOe
Mike Shick
www.medesigns.us
Message 5 of 19
AllenJessup
Sorry. That link is blocked by our firewall.
Allen Jessup
Message 6 of 19
Pointdump
Mike,
The Discussion Administration pulled your post off another thread and made it a shiny brand new thread with a new title.
As for your jpg, which one do you want to put in a drawing?
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 19
mikeshick
Any one of the folders has a jpg that was downloaded via national map viewer.
Mike Shick
www.medesigns.us
Message 8 of 19
mikeshick
See if a couple of samplers come through.
Mike Shick
www.medesigns.us
Message 9 of 19
Pointdump
Mike,
Working OK for me. Be sure to start with a Metric Drawing and assign it a UTM83-10 Coordinate System. MAPIINSERT will drop one of those JP2 images in right on the chile.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 19
AllenJessup
I was also able to insert the JP2 file. Make sure the JPW file is in the same folder and set the coord system as Dave said.
Allen Jessup
Message 11 of 19
mikeshick
thanks, guys.  Pardon my ignorance, but how did you know of the coordinate system UTM83-10 metric...and where do you see the jpw file.  Finally, can you explain what you are doing with the jp2 file?
Mike Shick
www.medesigns.us
Message 12 of 19
AllenJessup
I don't know how Dave did it. But I opened the 10SGD.prj file in notepad and read it from there.
There are 2 files a J2W and a JGW that go with the two flavors of rasters.
I created a new drawing and set the correct system. Then typed MAPIINSERT, browsed to the folder I had unzipped the files into, selected the JP2 file and hit OK. The image above is a screen shot of the contents of the folder I unzipped the files to. BTW The 2 red blobs to the left indicate raster files.
The folder contains everything from an ESRI project and not all pertains to brining a raster into Civil 3D.
Allen Jessup
Message 13 of 19
mikeshick
Ah, I see the jgw, but in previous email and I've used before you mentioned the jPw. Thank you,
Mike Shick
www.medesigns.us
Message 14 of 19
AllenJessup
Sorry. Age is catching up to me a little faster that I'd like. Smiley Very Happy
Allen Jessup
Message 15 of 19
mikeshick
My hat is off to you. I'm getting older every day, too...and feeling it 🙂
Thanks for all your help.
Mike Shick
www.medesigns.us
Message 16 of 19
Pointdump
Mike,
"...how did you know of the coordinate system UTM83-10 metric..."
I did same as Allen. Always look for a PRJ or World File to find out what Coordinate System the data is in.
PROJCS["NAD_1983_UTM_Zone_10N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-123.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
Now on to the other data. You can make a surface in C3D with either the ArcGrid (ADF) data or the IMG data, but the GridFloat folder has ESRI proprietary files in it that won't work in C3D without using third-party software to "convert" into something useful.
Dave
Dave Stoll
Las Vegas, Nevada
Message 17 of 19
mikeshick
Thank you, Dave. How do you view the data in the prj or world files?
Also, is there a convenient way to translate the data into another coordinate system? Say, nad27 in feet?
Mike Shick
www.medesigns.us
Message 18 of 19
Murph_Map
I'm not Dave, but you can read the prj or world files with a standard text editor or Notepad.
The only way to translate the image to another coordinate system is with Raster Design or using the Map3D tools to attach and query a dwg is inserted into but that does not change the image only the dwg that it is in.
Murph
Supporting the troops daily.
Message 19 of 19
Pointdump
Mike,
"How do you view the data in the prj or world files?"
Open any PRJ or World File with any text editor.
"Also, is there a convenient way to translate the data into another coordinate system? Say, nad27 in feet?"
No easy answer here. Depends on the data and how you bring it in to AutoCAD. Sometimes it's not possible in C3D and you have to resort to third party software, like QGIS, Microdem, MapWindow, GeoViewer, OpenEV, Global Mapper, etc...
Dave
Dave Stoll
Las Vegas, Nevada
