Insert PDF
Insert PDF
arpenteur
Message 1 of 13
Insert PDF
arpenteur
Hello everyone,
I know how to insert a PDF into the drawing.  My question is.  Is there a way to insert a PDF, that won't be heavy.  Every time I insert a PDF, my drawing becomes very slow.
Thanks...
Replies (12)
Message 2 of 13
I convert the pdf to a tiff and attach the image for that very reason. It's not acceptable to have the delays you get with a pdf attachment.
Message 3 of 13
samir_rezk
Hi @arpenteur
Like @Anonymous mentioned! Tiff files are your best option for this type of attachments! However I prefer to simply import it as AutoCAD geometry using the PDFIMPORT command!
Hope this helps,
Samir Rezk
Technical Support Specialist
Message 4 of 13
arpenteur
HI drenaud
Thanks for your suggestion.  It's working well.
Message 5 of 13
arpenteur
This makes a big difference. I can also delete lines that I do not need.
Thanks...
Message 6 of 13
Pointdump
Hi David,
I never thought of trying this. What's the best way to convert a pdf to a tif? I tried just now in PhotoShop and it seems to work pretty well, although the new tif was sizable. How do you attach the tif?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 7 of 13
samir_rezk
Hi @Pointdump
use the attach image command to attach the tiff just like how you’d attach a jpg!
Most pdf application can save as a tiff as well like acrobat or Bluebeam
Samir Rezk
Message 8 of 13
Pointdump
Hi Samir,
Thank you.
I only have Adobe Acrobat Reader DC, so no option there to save as tif. (I tried just now.) PhotoShop Elements works. Paint won't open a PDF, so no go there. I'll nose around and see if any free programs will convert a PDF to TIF.
It's been a while since I attached a PDF. Just now tried Attach >> PDF Underlay and it works. Also External References >> Attach PDF seems to be the same thing. Back in the day I used to attach and scale a PDF of Footings or Floor Plans as a background to my construction linework, and I remember my drawings became as slow as molasses in January.
I guess both IINSERT and MAPIINSERT will work also.
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 13
arpenteur
Hi Pointdump,
I just used the PDFIMPORT as suggested, and it works GREAT!!! I can also edit some lines in the PDF plan that I inserted.  Also - nothing as slow as molasses...
Message 10 of 13
AllenJessup
@Pointdump
Dave, I use https://www.irfanview.com/
Allen Jessup
CAD Manager - Designer
Message 11 of 13
Pointdump
Hi Roger,
Thank you.
I guess your PDF's are AutoCAD created so you can take advantage of vector information. But what about PDF's without vector geometry or raster images?
Dave
Dave Stoll
Las Vegas, Nevada
Message 12 of 13
AllenJessup
PDFIMPORT can work. But I think it only works on PDFs that have vector info. Not the pure raster ones or converts them to a raster.
Allen Jessup
Message 13 of 13
Pointdump
Allen,
Thanks. I'll try IrfanView.
"PDFIMPORT can work. But I think it only works on PDFs that have vector info."
I think you're right. Here's a side-by-side of a PDF. Left side I used Attach, right side I used PDFImport:
Dave
Dave Stoll
Las Vegas, Nevada
