Announcements
Insert a JPEG Map to Scale
I am attempting to insert a JPEG map I created in ArcMAP into paperspace in Civil 3D, but when I use the "MAPIINSERT" function, the scale of the image becomes very small and the only way to expand it to the true size is to create a polygon with the dimensions of the map created in ArcMap and then scale the small image to the size of that polygon. This method, however, loses the image quality as the expanded image is grainy.
Do any of you know a way I can just insert the JPEG into Civil 3D paperspace as its actual size? Every image I import comes in as a fraction of the size.
Any help would be very much appreciated!
Best,
Jacob
rkmcswain
Are you trying to spatially locate the image also? Can't ArcMap make a world file for the image?
Re: http://desktop.arcgis.com/en/arcmap/10.3/manage-data/raster-and-images/world-files-for-raster-datase...
R.K. McSwain     | CADpanacea | on twitter
sboon
When you export from ArcMAP do you get an associated world file?  It would likely have a .JPW extension.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
tcorey
Use AutoCAD's Attach command and the JPG will only be scaled if you type numbers in the scale input boxes.
This will not georeference the image.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
bforr
make sure the units you created it in match the insertion units in cad and your drawing is set up accordingly
