Infrastructure Parts Editor 2024 - Tee Refuses to Accept Nominal Diameter Size
Against all reason I'm trying to create a pressure catalog that has AWWA C110 ductile iron fittings and have a problem with creating a tee.
I'm using the OOTB CPTS_MJMJMJ template.
On the Part Editing tab I'm trying to change the nominal diameter (1), nominal diameter (2) and nominal diameter (3) values. These are the sizes for each port with 1 and 2 being the main size and the tee being 3. When setting the initial sizes IPE does not create multiple entries for each size so those have to be manually created. I.e., IPE only creates a single 3" row that I edited to be 3"X2" and the user must create or edit additional rows to have a 3"X3" tee. This worked at first, but when I began editing the initially created 6" row to be 4"X2" the Nominal Diameter (1), Nominal Diameter (2) and Nominal Diameter (3) does not accept any value other than the initial 6.
Is there some kind of hard-coded value that IPE is overriding the user or is this yet another defect with IPE that'll never be fixed?
Windows 11
32GB RAM
