AutoCAD help says:
"An infill grading has no criteria applied to it. Any area bounded by feature lines or lot lines that is not already a grading can be converted to an infill grading."
So given an area enclosed by a feature line, an infill grading can be created. Using the same features line, an feature line grading can also be created.
I just wonder what is the difference between these two surfaces? They both have no criteria applied to them.
Xiangyu
When you apply a grading to a feature line, C3D automatically applies an infill between the parent featureline and the one created by the grading. When you look at the grading in a 3D view with a shading style applied you see the infill. Consider the case where you have a building pad and you apply a grading to the perimeter that targets the existing ground. If you look at the grading and the pad featureline in a 3D view you'll see the gradings have infills but the pad does not. Also if you set the Create Surface option in the grading group settings you'll also see the resulting surface does not include area inside the pad.
There are 2 ways to remedy that hole in the surface:
1: Add the building pad featureline to the surface as a breakline which causes the surface to triangulate across the open area.
2: Add an infill inside the building pad featureline to add that area to the grading.
Does it matter which approach you use? For the most part, no. You can get the same results either way for surface models and cut/fill volumes . But there are advantages to using infills, namely:
1) The gradings won't have holes when viewed in 3D
2) Any additional gradings that may project onto the pad will intersect the infill.
3) You can use the earthwork balance tool to automatically adjust the gradings to achieve balanced quantities.
neilyj (No connection with Autodesk other than using the products in the real world)
Joe Bouza
excuse me but are you sure?
I'm running c3d 2013 and I tried editing a closed fline with an infill applied and the grading reshapes automatically
Pardon me; I often think everyone is in my head when a say something.
In some cases they cant react to changes. for example lets say you use a projection grading by distance and grade and tie that to an infill via connecting the projection line with your infill area. Change the projection distance and the infill is gone. (not dynamic)
Joe Bouza
See what I mean! I thought thats what I said 🙂
Bill has been after me for years for that. My own little language I guess
Joe Bouza
Joe Bouza
The point is, in a projection grading if I adjust the parent FL the projection reacts. If I adjust the criterior of the projection grading everything adjust.
To adjust an infill you have to work at it with various tools and, at times, some brain power.
To me that makes an infill less dynamic than a projection grading. I know the infill warps to "user" intervention, but the key word is intervention. The infill is as dynamic as the feature lines it is bound by. Thats all.
Don't get me wrong Neil I think infills are essential.
And by definition all an infill does is tell the grading its ok to triangulate across me.
Joe Bouza
You think so.
: always active or changing
: having or showing a lot of energy
: of or relating to energy, motion, or physical force
Of course if you consider any changes that ignore the original criterior and/ or intent to be represented in your finished product then yes Infills are dynamic.
Joe Bouza
Dear NeilW,
Are you still answering questions regarding this topic? I have a simlar problem - but I am not dealing with a building - I have a simple sloping plane. I have used the closed feature line as a breakline (image1)
Then I greating a projection grading to the slope using '3to1 to slope'as the criteria
the contour disappears as does the surface. within the simple 2% plane. Can you advise me on how to have the slide slopes as well and the contour within the interior be united in the same surface rather than creating a seperate surface for the simple plane?
In the end - I created two surfaces and pasted the sloped plane into the side slopes. I though this was a bit inelegant and was searching for an alternative.
thank you and i apologize for the 'beginner' level question
Hope
I think that's also the 'gradings can be problematic' issue even though that's just a small part of the problems that may or may not appear...
John Mayo
Joe Bouza
