Improve Grading Group Properties.
joantopo
joantopo
Scenario:
A grading is using a "No Display" style.
Workflow:
I have to edit the "No Display" style to show at least one component. Once I can select the grading in the drawing, in the ribbon I can select the Grading Properties to change its grading style to another one.
Finally, I have to edit "No display" style again.
To avoid this, it would be interesting that we were able to change the grading style for each grading directly from the Grading Group Properties.
Due to a grading object doesn´t have a name or description, it will be always "Grading- counter"in the same order they were created.
the column of "Grading Style" must be a ComboboxColumn, so the user can select another grading style from here.
Thanks.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Replies (0)
