Importing .tiff raster image to civil 3D and creating topology/surface
shershahbacha9
Message 1 of 8
shershahbacha9
I have a .tiff raster image which i am sharing here . i want to import it to civil 3D and create surface/topology out of it. i somehow got a method to import it to civil 3D but dont know how can i make surface/topology out of it . i also tried by the option "create surface by DEM" but its not working . you can see the image format attached here.
Replies (7)
Message 2 of 8
rl_jackson
See if this information helps.
https://forums.autodesk.com/t5/civil-3d-forum/creating-surface-from-geotiff-dem/m-p/7826894#M364958
Rick Jackson
Survey CAD Technician VI
Message 3 of 8
Pointdump
Bacha,
Your Tiff is just a Raster Image with no usable Elevation Data for C3D to create a Surface from. QGIS says it's in ETRF89.TM32 (EPSG:3044) Projection, and that seems to line up nicely with Bing Live Maps. You can use MAPCONNECT to bring in the image, but you won't be able to create a Surface from it.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 4 of 8
Pointdump
Bacha,
If you'd like some serious, kick-butt LiDAR Elevation Data, look >>>Here<<<.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 8
shershahbacha9
you mean i cannot produce surface in just Civil 3D or also in QGIS we cannot produce surface
Message 6 of 8
shershahbacha9
Yes Dave . i need a source in Germany which is more reliable so that i make a surface/topography out of it and import it into Revit so that in the end while placing my building on 3d site , i know my required cut and fill
Message 7 of 8
Pointdump
Bacha,
Nope. You won't be able to create a Surface with that Raster Image.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 8
samir_rezk
Hi @shershahbacha9
It won’t be a straight forward approach, but you can use AutoCAD Raster Design to vectorize the image, and/or create analysis styles that better help visualize the terrain.
Take a look at this toolset:
https://www.autodesk.com/products/autocad/included-toolsets/autocad-raster-design
hope this helps,
Samir Rezk
Technical Support Specialist
