Importing Shapefiles into Civil 3D
Message 1 of 11
I'm trying to import contours from a .shp into civil 3d. When they come in they all have 0 elevation data. After looking at other posts/forums, I did all the steps through the "define query" dialog. However, when I get to "Set Property Alterations" dialog box and hit "Expression" the only folder available to me is "Properties". Why is there no "Object Data" folder? (This is what I am told I need to set the elevations of my contours)
Thanks!
Ben Chronister
@BushW has edited your subject line for clarity: Importing Shapefiles into AutoCAD
Replies (10)
Message 2 of 11
neilyj666
Can you post your files so someone can take a look for you?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 11
Joe-Bouza
In the surface panel you can create a surface from GISData directly without the need for poly line contours
Joe Bouza
Message 4 of 11
Pointdump
Hi Ben,
Welcome to the Autodesk Forums.
Let's check your data. Please zip together and post the DBF, PRJ, SHP, and SHX files from your Shapefile.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 5 of 11
BushW
Hi @Anonymous
Please review this AKN articles to see if this information is useful in importing shapefiles into Civil 3D. Hope this helps!
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit and thank you for doing so, and I'm here to help.
Wendell Bush
Civil Infrastructure Technical Support Specialist
Message 6 of 11
camptech
Where is this mythical surfaces panel to which you refer?
I am using Civil3D 2018, and can find no surfaces panel anywhere.  I've checked all the panels under all the ribbon tabs under the Civil3D, Drafting & Annotation, 3D Modeling, and Planning and Analysis workspaces.  I must be blind.  Any help appreciated along with any tips, links, URLs, pointers to tutorials or other forum posts that detail how to create a Civil3D surface straight from GIS data.  In particular, I am trying to work with 1ft contour LIDAR data from the Denver Region Council of Governments (DRCOG) mapping which is in the form of SHP files.
Thanks in advance.
Message 7 of 11
wfberry
OK
Go to the HOME Ribbon panel
Move over a "notch"
Select the down arrow on surfaces.
Bill
See your Opthalmologist
Message 8 of 11
camptech
Open my mouth, ask a question, then I discover it as someone else answers on the forum... C'est la vie.
For those playing along at home, I found Create Surface from GIS Data  (Command line: CreateSurfaceFromGISData) here:
Civil3D (workspace) > Home (ribbon tab) > Create Ground Data (panel) > Surfaces (drop down menu) > Create Surface from GIS Data
Message 9 of 11
codee
There is not a surface panel for this. Instead go to the "HOME" tab and select the surface pull-down menu. There you will find the option.
Message 10 of 11
camptech
I'm kind of confused...
Isn't that what I just illustrated in my last post -- a very detailed description of how to navigate to the surface pulldown menu -> CreateSurfaceFromGISData command along with accompanying screen cut and paste?
Message 11 of 11
That is extremely helpful, thank you.
