Civil 3D Forum
Import Profile View Crossing Label Styles from other DWG
6 REPLIES 6
antonioygeo
473 Views, 6 Replies
I'm trying to transfer some Profile View Crossing Label Styles from one drawing to another. I've tried drag and drop from the Toolspace Masterview, and the IMPORTSTYLESANDSETTINGS command, however nothing seems to work. Is there a workaround, or is this a known issue?
6 REPLIES 6
Jeew-m
in reply to: antonioygeo
When you are dragging styles make sure that they do not have the same names.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
antonioygeo
in reply to: Jeew-m
Hello @Jeew-m @, sure, my styles don't have the same name. Have you managed to transfer them? Because if you have, that means that I am doing something wrong.
Jeff_M
I just copied 2 Profile Crossing label styles from a drawing to another by drag-drop. C3D 2022 1.1 Update
Neilw_05
No idea why it doesn't work for you. A workround could be to add it into a new empty temp file and try bringing it in from there. If that doesn't work, attach the temp file as a style reference and update that way. Let us know if you get it sorted out. This is all contingent on being able to add it to a temp file. You could try adding it to the temp file with a style reference too. That way you don't risk trashing all the styles in your live file.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
antonioygeo
Ok, seems like I was doing the drag n drop wrong. Thanks for the answers.
However, I noticed that with the IMPORTSTYLESANDSETTINGS command, i can't transfer the labels between my drawings. On the other hand, when I attach the same dwg as a style reference this seems to work. I think this is kind of weird, unless I am doing something the wrong way again. C3D 2022 1.1 Update
Neilw_05
Yes it is weird if drag and drop doesn't work. I suggest you file a support request and work direct with Autodesk on that.
Meanwhile it sounds like you have a workaround.
WIN 10 64 PRO
Rail Community
