I draw Lines between 2 cogo points from node to node
masonbrown
masonbrown
When drawing lines between cogo points-from node to node-the line goes from that spot elevation to the other spot elevation.
Is there a way to draw these lines from point to point, but at elevation zero?
thanks,  Mason Brown
Draw a polyline instead of a line.
jeff_rivers
At the command line enter OSNAPZ=1
OSNAPZ Set to 0 will use the current entity's Z value for commands
OSNAPZ Set to 1 will use the current UCS Z value for commands, and will thus ignore the Z value of the selected entity if it differs from UCS Z.
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Jeew-m
Dear Friend,
You can use FLATTERN command and select the line. Then it will set to elevation 0 both ends.
Otherwise type command ELEV and set it to 0 (Or any desired elevation) and draw polyline instead of line.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
ChrisRS
The polyline will have the elevation of the first point you snap to unless OSNAP = 1
(See Jeff Rivers solution below)
Christopher Stevens
