I am DONE with REFEDIT!
I have been having a relatively good experience with REFEDIT... until yesterday.
REFEDIT had been fraught with problems for me until AutoCAD C3D 2017. I had begun trusting it again. Until yesterday, I had not seen any problems in AutoCAD C3D 2019. Then disaster struck. I tried to REFCLOSE/Save after making edits and it refused. I could not do anything but REFCLOSE/Discard. Today, I opened the file that I thought I had lost all of my edits to yesterday and they were all there... editing as I had intended... or so I thought!
It turns out that ALL of the layers in this drawing now had the name of the file that it was attached to during my REFEDIT session as a prefix and separated with a vertical bar just as if they were Xref layers in the current drawing and belonging to the file I was in when I used REFEDIT yesterday.
I learned this after I ran Audit on the drawing (which is standard practice after I PEDIT/JOIN polylines because that INVARIABLY will cause errors in the drawing... most often in the Layer table. AutoCAD repaired all of the layers by changing their names to:
AUDIT_I_180615103116-0
AUDIT_I_180615103116-1
AUDIT_I_180615103116-2
...etc...
AUDIT_I_180615103116-116
Not cool Autodesk!
Now I go get my backup file and NEVER use REFEDIT again.
Product Ver.: 13.6.1781.0 Civil 3D 2024.3 Update
Built On: U.152.0.0 AutoCAD 2024.1.2
27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
8.6.52.0 AutoCAD Architecture 2024
