& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I am recreating a project done in Pondpack to make a case at my workplace to switch to either SSA or Hydraflow. I did put the same data in both and on 1 year storm the results are similar but when i check the 100 year storm the differences are significant. The difference in Hydraflow seem to be the time interval under the hydrologic data area. If use the 3 minutes interval as Pondpack does the result is lower peak flow but 2 or 1 minute result in an significant increase. What should be the right interval ? SSA results are close to Pondpack but the reports in SSA are not as clean as Hydraflow. How can i get the same results on both SSA and Hydraflow? whats different on the equations that triggers different results. i am attaching the files for your review. Thank you in advance.
how far off are you? usually flows are higher with lower time intervals. perhaps try all of them with 6 min interval, assuming all your Tc are higher than that.
Just to give you an example., if you look at the files EDA-2D on H&H wit time interval set to 1 min. i am getting 39.33 cfs. on a 100 year storm. In SSA same data, same storm is just 33.46 cfs. It is a big difference. What should be the ideal interval number? Which software is right?
The results for the same area EDA-2B on Pondpack are closer to SSA results for the 100 year storm. The method used in all is TR-20-TR-55. The time interval on SSA is the default (not sure where to modify it), Pondpack is using 5 min. for time intervals, H&H won't let me set it to 5 min. because it cannot be 50% greater than the time of concentration. If i set it to 3 min i get less than Pondpack. If i set it to 2 min. i get higher than Pondpack.
SSA = 33.46 cfs default
Pondpack = 33.14 cfs 5 min. interval
H&H = 39.33 cfs 1 min. interval
We like the reports in H&H but we cannot use it until we figure out what should be the time interval setting. Should. if my time of concentration is 5 minutes, what should be the time interval?
Thank you Kevin. Based on his finding it looks like for a 5 min. TC. the more conservative interval should between 2-3 mins.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
