How do you quickly create a legend for a plat showing the various items measured in the field?
I have read about the "Legend" tool, but that seems geared towards surfaces and area (e.g. hatches) applications.
Has anyone created a freely available legend-tool where one simply types "createlegend" (or something similar), then goes about picking items on the drawing --OR-- inserting blocks and then typing a description? The tool would then create a block that could be placed wherever you wanted it to go.
Otherwise, it seems such a chore: create a table, or an array of points (to anchor stuff), insert blocks at points, insert text (or mtext) at corresponding point etc etc. Or is the trick to create a legend once, as part of the template drawing, then you simply "update" or add to it?
If you have important survey data that needs to be part of the legend, but the survey points use a Point Style - Custom Marker, not a custom block, how do you place the custom marker in the legend? The only way that occurs to me is to create the legend in model space, off to the side, and then create or place a dummy COGO point at the legend location to get the Description Keys to put the appropriate point marker at the legend location. That seems rather cumbersome, and would seem to drive one towards using only custom blocks (so the block could be placed separately) thus defeating the idea of using Point Style - Custom Markers.
Advice / best practices welcomed. Thx in advance.
