HOW TO USE FIELD BOOK DATA
Message 1 of 10
Hi All,
I am trying to use survey data (.txt file comma delemited). when i use automatic linework "yes", it creates a mess. lines are all over the drawing and can't make correct survey figurea.
can anyone help me out please?
thanks
Mir
Replies (9)
Message 2 of 10
Have you read the "field to finish", in the help files
It helped me a lot.
Did you set the survey point coeds and the figure styles?
Message 3 of 10
Pointdump
Mir,
Can you post your survey data?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 4 of 10
Hi Dave,
Yes i can certainly send you my filed data. it is a .txt file. we use PNENZD(cooma delemited) .
please let me know how i can use them witout having all survey lines all over the drawing.
many thnaks
Mir
Message 5 of 10
Hi There,
where is exactly this "Field to Finish" file? Could you please let me know.
Many thanks
Mir
Message 6 of 10
Do a search in the help files for "field to finish" and you should find it. Autodesck also has an excellent book you can order that's geared for the survey aspect that Dave p sugested i get. I found it to be humongas help.
Message 7 of 10
HI There,
thank you for the suggestion. Is this book published by Autodesk? what is author's name?
could you also please let me know how i should order this book?
many Thanks
for the help
Mir
Message 8 of 10
Pointdump
Mir,
"...when i use automatic linework "yes", it creates a mess."
Looking at your point file, I can see why. In order for the automatic linework to work correctly, the description must signal when to begin and end the line.
1,18.6740,314.0320,942.6130,CL
Instead of "CL", you'll want to use instead "CL B" or "B CL" to start the line. When you want to end the line, use a description of "CL E" or "E CL".
And ahead of time you'll want to set up your Figure Prefix Database so that a description of "CL" uses a particular linetype and layer.
In the Help Files, I'd start here:
http://help.autodesk.com/view/CIV3D/2016/ENU/?guid=GUID-993EE89B-3E62-4FAA-BFE3-9A51560962D2
I found this book to be very helpful. (Note they have versions for Imperial and Metric.)
http://www.ascented.com/courseware-solutions/autodesk/courseware/autocad-civil-3d/2016/autocad-civil...
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 10
Hi Dave,
Thank you for the help. I figure the automatic line type for the field data won't be exactly automatic. I have to do lots of ground work and for each project it has to change as well.
Yes , I started that section of help file.
One thing I wanted to ask - if I rearrange all these survey data (using spread sheet and then save as .txt) by their code and renumber all the data, do you think it will work?
Thanks again
Mir
Regards
Mir Akbar
Works Engineer
Snowy Monaro Regional Council
81 Commissioner Street
(PO Box 714)
COOMA NSW 2630
Direct 02 6455 1831
Mobile 0431 516 001
Phone 02 6455 1777
Fax 02 6455 1799
www.cooma.nsw.gov.au
IMPORTANT NOTICE REGARDING CONTENT
Snowy Monaro Regional Council accepts no liability for the content of this email, or for the consequences of any actions taken on the basis of the information provided, unless that information is subsequently confirmed in writing. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
IMPORTANT NOTICE REGARDING CONFIDENTIALITY
This electronic message is intended only for the addressee and may contain confidential information. If you are not the addressee, you are notified that any transmission, distribution or photocopying of this e-mail is strictly prohibited. The confidentiality attached to this e-mail is not waived, lost or destroyed by reasons of a mistaken delivery to you. The information contained in this e-mail transmission may also be subject to Government Information Public Access (GIPA) Act legislation. If you have received this e-mail in error please contact the author of the message, as soon as practicable.
______________________________________________________________________
This email has been scanned by the Symantec Email Security.cloud service.
For more information please visit http://www.symanteccloud.com
Message 10 of 10
Pointdump
Mir,
Under "Process linework during import", you can select either "by point number" or "by import order". So you can rearrange your points and you won't have to renumber them.
Dave
Dave Stoll
Las Vegas, Nevada
