I often need to add grid coordinates to drawings. As this is becoming more frequent, I had a root around Google and discovered that I could set up a note label style to add an easting or northing to any point I click on. (Annotation - add labels.)
This is great, but I can't find a way to save it so that new dwgs list it as an available style. I have to create new styles for every new dwg.
I tried setting up the style and saving the dwg as a template file, but it doesn't work - a new dwg from that template still only has the default label style and not the easting and northing styles that I ceated.
How can I get these styles saved so that I don't have to redo them from scratch every time I need a labelled grid?
I'm using C3d 2019
