How to restore custom settings saved before reset to defaults
Kekekenn
Message 1 of 15
Kekekenn
I loaded an add-in that wiped out my ribbons. Switching workspaces and profiles back and forth did not work neither did a restart.  When resetting to factory defaults I choose the option to back up my custom files, which created a ZIP file.  The settings were reset and the ribbons are back but I cannot find how to restore the settings contained in the ZIP file.  I had numerous tool palettes that are captured in the ZIP file. It was really time consuming to create them and I don't want to have to repeat that effort.  I am running 2019 C3D.  Help
Replies (14)
Message 2 of 15
wfberry
Did you try the IMPORT AUTOCAD 20XX SETTINGS from your Windows Menu.
Bill
Message 3 of 15
Kekekenn
I saw that method in knowledge.autodesk but it does not appear in my Windows 10 menu.
Message 4 of 15
Kekekenn
If IMPORT AUTOCAD 2019 SETTINGS is not in my Win 10 menu, how do I get my settings back?
Message 5 of 15
AllenJessup
Are the ToolPallet file extractable from the ZIP file? Try extracting them to C:\Users\<USER>\AppData\Roaming\Autodesk\C3D 2021\enu\support\ToolPalette or whatever your _TOOLPALETTEPATH System Variable is set to.
Allen Jessup
CAD Manager - Designer
Message 6 of 15
Kekekenn
Thanks, I thought that would have worked too. But after restarting cad it still does not recognize them.
I am running a home license; I wonder if that's the difference.
Message 7 of 15
AllenJessup
You may have to import them. Open a ToolPalette and right click on a bland area. Select Customize Palettes. In the Customize window right click on the Palettes pane. Select Import and browse to your ToolPalette.
Allen Jessup
Message 8 of 15
Kekekenn
I tried that but it is looking for .xtp files.  The backup saved .atc files
Message 9 of 15
AllenJessup
That makes it difficult. I googled "How to import atc files in Civil 3D". There were a couple of suggestions. But I don't know if any of them will work.
Allen Jessup
Message 10 of 15
Kekekenn
I am still trying to wrap my head around how I am allowed the opportunity to back up my settings but not the ability to restore them in the format they were backed up.  The process does not seem to be well thought out...or not readily found.
Message 11 of 15
Joe-Bouza
options>>> profiles>>> export
Joe Bouza
Message 12 of 15
wfberry
Under the Windows 10 menu, look under  Autocad 2019.
Bill
Message 13 of 15
Kekekenn
Thanks Joe but that is what should have been done prior to the reset....and is what I will do in the future.  Unfortunately, the reset process offers the opportunity for a back up but it apparently does something different (ZIP file) than options>export (.ARG file).
Message 14 of 15
Kekekenn
And that is the problem; it does not exist. See the pic of my menu in the 3rd entry in this string.
Message 15 of 15
kyleoF6GUE
Was this ever figure out? I have the same problem with windows 10 for C3D 2023.
