![](/skins/images/22721C4AD6E1AA0F9EAB1A180619AF1C/responsive_peak/images/icon_anonymous_message.png)
Does anyone have a good workflow for creating Civil 3D surfaces from Lidar data in a different projection? I'm downloading Lidar data from MnTOPO (http://arcgis.dnr.state.mn.us/maps/mntopo/) and want to use it to create Civil 3D sections. The Lidar data is in UTM meters and my CAD drawing is in Minnesota state plane feet.
I can create surfaces using the Lidar DEM files, but I'm having trouble re-projecting and converting the elevations from meters to feet. I can re-project using ArcMap, but I don't have the spatial analyst to convert the elevations from meters to feet. Exporting/importing LandXML files doesn't work and neither does this: https://forums.autodesk.com/t5/autocad-civil-3d-forum/converting-dem-surface-from-meters-to-feet/m-p....
How else can surface be re-projected and converted from meters to feet?
Scott
