How to make two symmetrical curves (reverse curves)
esimpsonAUYZF
Observer
esimpsonAUYZF
Observer
Observer
I've been struggling with this issue for a while and I've finally had enough. I need to make two curves back to back that are the same radius and are tangent to two separate lines.
I need to connect sidewalk #2 to sidewalk #1 using two curves. I can roughly get the two curves to work but the radii are off a little bit (see the orange line).
I know that I can do some calculations, offsetting, and filleting to get the correct answer, but that takes a long time. Also if i have to change the two connection points, I would have to repeat all of that over again. I assume that there's a simple command for this that I just don't know about.
v-silvestre
Hi, would you mind posting your drawing?  Also, it looks like the point of connection on sidewalk 2 is fixed while the POC on sidewalk 1 can be free floating?  If so, that means it all depends on the size of the radii and this can have multiple solutions.  Is there a preferred radii?
brian.strandberg
I have always done this by drawing a line connecting my start and end of the reverse curve.  This is to make it easy to snap to the midpoint.
Start drawing a line at the beginning point, go into ARC mode, Indicate the starting tangent direction.  Snap to the midpoint of that line to end the first arc, then snap to the reverse curve endpoint.
Since this is alot of gibberish, I have attached a .gif.  Thanks.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
AllenJessup
Draw a line from the end of one side of sidewalk 2 to where you want the reversing curve to end on sidewalk 1. Draw another line over the side of sidewalk 2. Start the Arc command and hit enter when asked for the start point. This will make the arc tangent to the line you just drew. End the first arc at the midpoint of the line from sidewalk 2 to sidewalk 1. Immediately start another Arc command and hit enter for first point making the new arc tangent to the first one. End the second arc at the end of the connecting arc. The arcs should be of equal radius.
Allen Jessup
CAD Manager - Designer
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
