How to make Grade Lines at every fixed distance?
keyable
keyable
I’m working in Autodesk Civil 3D and would like to display grade lines along a profile at fixed horizontal intervals — for example, every 50 meters.
Like this:
I’ve already added a Vertical Geometry Band to the profile view, but it only displays grade data at geometry points (PVI locations), which makes sense.
Check screenshot below:
However, my goal is to show grade or elevation values at uniformly spaced stations, not just at geometry points.
Is there a way to create or display a grade line (or elevation annotation) at fixed distances along the alignment, such as every 50 meters?
Thank you in advance for any guidance!
neilyj666
Not sure about grade line but elevation can be shown - 10m spacing in this case
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Jeew-m
In profile view properties--> Bands tab
Uncheck grid interval and set the 50m interval as desired
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
keyable
"Vertical Geometry" doesnt have the Inerval option. Please check the screenshot of my profile's bands:
