How to make dxf file in civil 3d which can be used as dtm in leica cs20?
saleemniazi1525
Observer Observer
Message 1 of 8
saleemniazi1525
Observer
Observer
i have created a surface in civil 3d but I don’t know how to create a DTM which i can use in leica cs 20 controller. I tried exporting xml but shape of surface got distorted.
i am curious that few engineer uses dxf file as dtm model, can anyone help me if I can create that specific dxf file which i can use as dtm in leice controller. Thanks in advance.
Replies (7)
Message 2 of 8
rl_jackson
The C220 controller can import LandXML files as well. You should probably try that first.
Rick Jackson
Survey CAD Technician VI
Message 3 of 8
lim.wendy
Hi Saleem,
Welcome to the Civil 3D forum! I see you've posted a question. Did you get a chance to try Rick’s suggestion?
Let us know if that works for you or if you need further assistance!
If they helped solve your issue, consider hitting the "Accept Solution" button. This helps others searching for similar problems find the answer quicker. It also lets our community know which topics are resolved and which still need attention. Plus, it's a great way to show appreciation to the person who helped you!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 4 of 8
saleemniazi1525
Observer
Observer
Hey rl_jackson thanks for your response. I tried that but it gets distorted as new triangles formed.
however, i found the solution by just exploding it into 3d faces.
initially when it was not exploded and i tried to import it into leica as dtm, it was responding as no 3d face found. But after exploding same file in civil 3d for 2 times untill i got 3d faces, it was fine and i was able to import it as dtm in leica cs 20 controller.
Message 5 of 8
Udo_Huebner
Instead of exploding the original Civil Surface simply extract displayed triangles as 3DFACE objects using command: SurfaceExtractObjects.
Gruß Udo Hübner (CAD-Huebner)
Message 6 of 8
saleemniazi1525
Observer
Observer
Thanks everyone
Message 7 of 8
saleemniazi1525
Observer
Observer
udo_huebner, can you please also guide me how to covert this drawing so that i can import it into gps of excavator. I have seen their format and it is written as one file as geo and second as trm
Message 8 of 8
wuidopareja
Community Visitor
Community Visitor
ME PODRIAS AYUDAR
este es mi correo [email protected]
