how to make dicision for SAC if EG cuting position bench???
nugsanga
nugsanga
how to make dicision for SAC if EG cuting position bench???@lim.wendy@Udo_Huebner 111111.png
ecfernandez
Hi, evaluate this with a Decision
AP28.DistanceToSurface(SurfaceTarget)<0
SurfaceTarget=The target that you have set in the "Target Parameters" tab
Take into account the following:
The result of the evaluation would be the vertical distance from the point to the SurfaceTarget (if the point
is above = positive, point below = negative)
When you have that, if the result is "true," it would mean "cut" and "fill" for the opposite. According to this, set the correct geometry on each logic branch.
I hope this helps. Best regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
nugsanga
  1. this is my pkt, i have tried it doesn't work. please help me. maybe you can help add decision in my pkt
ecfernandez
Hi @nugsanga, unluckily, I didn't understand where you wanted to place the decision into your subassembly. But I decided to create a sample file so you can see the cut&Fill analysis, understand it and apply it to your custom subassembly in the way you expect. I have attached a ZIP file. Check it out.
I hope this helps. Best regards.
Camilo Fernández
LinkedIn
M_Obradovic
Hi nugsanga,
As ecfernandez said I also don't understand where you want to put the decision. I would just like to suggest another way to create a decision using math functions. This equation for point P2 completely replaces the decision and solves it with only one point.
nugsanga
more or less like this sir. I have a slope with a ratio of 1:2, 6 meters high and 12 meters wide. when I create the first formula ap1.y < ap.2y. if it is true it will make a slope, if it is wrong it will make a bench. that is my formula with the existing ground notes cutting the slope. when an error occurs then the bench will be formed with a slope of 4% inward so that the elevation of the bench is less than 6 meters due to the 4% slope of the bench. and when the existing ground cuts the bench with a slope of 4% then my formula doesn't work. how to add a second formula so that if the existing ground intersects on the bench my slope will continue and not form the bench.
@ecfernandez @M_Obradovic
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
