How to load "civil 3D toolbar-feature-line"?
hnguyen7HWBJ
hnguyen7HWBJ
I am working on the grading plan using Civil 3D (2019) and I need the tools to do the work. Could you help me to load the "Civil 3D toolbar-feature-line please?
Sorry, I have already type "Menuload" it pops up Loaded Customization Groups but does not have the Civil 3D toolbar-feature-line to select.
Hien
Accepted solutions (3)
KMercier_C3D
Do you have the ribbons shown? The feature line tools are on the Home ribbon as shown in the image below.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
hnguyen7HWBJ
Ms. Mercier,
Yes, I do have the Ribbons shown.
The Civil 3D toolbar-feature-line looks like the attached image below and it contains these icons:
. Elevation Editor...
. Quick elevation edit
. Edit elevation
. Set Grade/Slope Between Points
. Set elevation by Reference
. Insert High/Low elevation point
. Elevation from Surface
. [Insert P]
. [Delete P]
. Break
. Trim
. Join
. Reverse
. Fillet
. Fit Curve
. Smooth
. Weed
. Stepped Offset
BrianHailey
That looks more like an image of a menu and not a toolbar (haven't used toolbars in Civil 3D in ages so I could be wrong). If you want, you can turn on the menu and then you'll have access to the tools there. Set the system variable MENUBAR to 1 and then click on the grading menu and there's two options there, "Edit Feature Line Elevations" and "Edit Feature Line Geometry".
2018-10-04_1542
Like I said, you can turn it on, but why? If you want access to those tools, simply go to the Modify tab on your ribbon. Much faster in my opinion.
2018-10-04_1544
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
hnguyen7HWBJ
Mr. Brian Hailey,
That what I am looking for.
Thank you very much for showing the detail of the images.
Hien
