Civil 3D Forum
How to export surfaces in LandXML automaticly in seperate files
14 REPLIES 14
Message 1 of 15
cyberflow
952 Views, 14 Replies
Is there a way to export several surfaces into seperate XML files automaticly in one single commande ?
The workload is pretty heavy and we're trying to find a way to optimize our workload.
Using : Autodesk Civil 3D 2022& 2023
AKA Frank Freitas, Senior Roadway Designer @ Kiewit
14 REPLIES 14
Message 2 of 15
jatin.anand
in reply to: cyberflow
I don't think there is a method to do this, you can just right-click on each surface in the prospector tab & export it to XML.
Jatin
Message 3 of 15
cyberflow
in reply to: jatin.anand
Hi @jatin.anand, thank you but that's what i was trying to avoid to do the repetitive action of exporting one at a time.
Message 4 of 15
244311
I need solution , I have same problem
Message 5 of 15
Alfred.NESWADBA
in reply to: 244311
>> I need solution
That are kind words ...
But there does not exist such an option OOTB.
You might use command _WBLOCK to create a new drawing from each of your surfaces, then open that drawing, run command _-AECCLANDXMLOUT to get just that exported, what you have selected during the WBLOCK.
With a bit of development knowledge that can be done automatically.
You might also put that wish into the Civil 3D Idea Station >>>here<<< and hope you get a lot of likes.
There you should also mention what should happen with the objects which are bound to your surfaces, like when you export an EG surface and there are 3 alignments, profiles, ... should they be exported too (as they all depend on that one surface you want to export) or should they be ignored (and so the relation surface to alignment ignored)?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 6 of 15
Neilw_05
Do you know a single XML file can contain multiple surfaces? What is your reason for putting them in separate files?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 7 of 15
cyberflow
in reply to: Neilw_05
Hi @Neilw_05
It's our construction department and our project engineers they prefer to know everything is seperated.
Message 8 of 15
Neilw_05
It figures. You could also edit the XML file after export, making a copy for each surface and deleting the other surfaces. It's still a tedious process but probably faster than waiting for C3D to export each surface one at a time.
WIN 10 64 PRO
Message 9 of 15
cyberflow
I've tought about that workflow.
But i told myself that it could be to much of a human risk factor in the process.
I guess there's no addon or lisp that can do this.
Message 10 of 15
TerryDotson
We'll be adding this to C3DTools today.  If you would like to test it, request an evaluation.
Message 11 of 15
TerryDotson
in reply to: TerryDotson
Export any or all TinSurface or GridSurface objects in a variety of formats, including LandXML for TinSurfaces.
Message 12 of 15
cyberflow
Pretty cool ... but i'm not sure il'l be able to convince our department to buy software for this.
Message 13 of 15
ishaq03
I know this is the old post but may be you will get the solution here, As per jeff provided the dll file.
https://forums.autodesk.com/t5/civil-3d-customization/export-design-surfaces-to-individual-landxml-f...
Message 14 of 15
cyberflow
in reply to: ishaq03
I like his idea of using XMLnotepad !
Good to know that little software exists : https://microsoft.github.io/XmlNotepad/
Message 15 of 15
ishaq03
look it once this video also.
Rail Community
