Civil 3D Forum
Search instead for
How to enter a carriage return in a Sheet Set titleblock field?
32 REPLIES 32
Message 1 of 33
jeff_rivers
2584 Views, 32 Replies
My titleblock uses sheet set fields for all the text entries now, and the sheet title is multiline text tied to the Sheet Title field.  For one sheet the actual sheet title is too long for the first line so it wraps down to the second line automatically.  Great so far, except that the break where it wraps is at an awkward place with respect to the text.  Is there a way to code a hard linebreak into a Sheet Set field?
That is, what I get is:
PEDESTRIAN BEACON AT 117TH ST
W
What I'd rather see is:
PEDESTRIAN BEACON
AT 117TH ST W
I tried using the /P but Sheet Set manager really doesn't like that. So as a workaround I put a bunch of spaces in the sheet title to move the linebreak where I want it to be but that seems crude.  Is there a way to code a linebreak into a sheet set title where I want it to be?
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
32 REPLIES 32
Message 2 of 33
roskirko
in reply to: jeff_rivers
Do you mean to use Alt-Enter for a new line?
Geographic Information Systems
Fanshawe College
Message 3 of 33
rl_jackson
in reply to: roskirko
Message 4 of 33
jeff_rivers
in reply to: rl_jackson
Same result, I get the error that SSM doesn't like symbols:
Jeffrey Rivers
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Message 5 of 33
jeff_rivers
I didn't think about that!  It works in Excel to add a carriage return to a cell, maybe it'll work in Autocad too.
Unfortunately, I just tried it, and the SSM textbox ignores that key sequence completely.
Jeffrey Rivers
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Message 6 of 33
Joe-Bouza
use the enhanced editor and squeeze the width, just like a piece of MTEXT.  that is  the beauty of the ML attribute.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 7 of 33
Hidden_Brain
in reply to: Joe-Bouza
Joe,
i struggled with this recently, can i get the ML attribute to output in 3 lines?
line 1: CONSTRUCTION STAGING
line 2: STAGE 2
line 3: -2-    *
*if stage spans multiple sheets
all text in ML attribute is using SSM>Sheet Title
Message 8 of 33
jeff_rivers
Joe, did you see my original post?  The requested sheet title is 31 characters long, and the available space is only 24 characters long.  I'm familiar with the width property of atttext, but I don't think shrinking 31 characters down to fit a space meant for only 24 characters is going to be legible.
Jeffrey Rivers
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
Message 9 of 33
Joe-Bouza
Yes I did. This is the way I understood your problem, sorry if I misunderstood:
https://autode.sk/2VwG4Xs
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 10 of 33
Joe-Bouza
in reply to: Hidden_Brain
Hello HB (Avishek)
did you get to see my screen cast? was it helpful
when you define a Multi-line attribute you give it a default width (where to wrap) typically the width of the area in the title blocks border. From there if Sheet title is longer than that the width can be adjusted like MTEXT editor as demonstrated in the screen cast.
Three lines as shown? we would be challenged for sure. you might want to consider addition custom fields to handle the third line as needed. Note with BATTMAN you can make attributes visible or invisible upon need
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 11 of 33
ChrisRS
SSM is not able to recognize line breaks. As @Joe-Bouza showed, you can force a break at by the with of you attribute field, but that gives you limited control.
I am to an expert, but my opinion is that 2 or 3 line labels are best handled using 2 or 3 SSM fields.  @Joe-Bouza alluded to this as well.
This is an AutoCAD issue. You might wan to check the AutoCAD Forums, but I have not been able to find anything useful on this topic. This would be a good topic for the AutoCAD Ideas Board … if one existed.
You could add this to the AUGI Wish List, or report it at the Autodesk Feedback page: https://www.autodesk.com/company/contact-us/product-feedbackautocad (This looks to be a black hole, but I am told it is for real.)
would be a good top
Message 12 of 33
Joe-Bouza
in reply to: ChrisRS
I concur.
the top line width governs the wrap
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 13 of 33
Hidden_Brain
thanks Joe, very helpful. i have been adjusting the wrapping with the grips as you show but i am having trouble getting it into 3 lines, please see below. perhaps i have to use a custom field like you mentioned.
Message 14 of 33
Joe-Bouza
Hi Avishek
Looks good from here .
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 15 of 33
Hidden_Brain
Joe,
i was trying to arrange it as-
line 2: STAGE 2
line 3: -2-
sadly, the best i could get was in the second screenshot from my earlier post. now if there is some trick to "selectively" grip edit and achieve what I am after, that will be dandy!
Message 16 of 33
Joe-Bouza
Avishek
Abandon hope on that wish. Focus on the ML attribute is good for on 2 lines and a special field for any potential 3 liners.
Alternately: leave -2- out of the SSM name, enter the enhanced editor manually after the width adjustment, manually enter the CR and -2- for the third line?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 17 of 33
MMcCall402
Weird idea:
Fight this in the opposite direction.  Replace the space between words with a non-breaking space to prevent the width limits of a multi-lined attribute from forcing a line shift and then only use a normal space when you want a line shift. A Shift+Ctrl+Space makes a non-breaking space but you can't enter it into the Sheet set manager directly. You can however copy it in from an Mtext and continue to copy and paste it in as needed once its in there.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Message 18 of 33
Joe-Bouza
in reply to: MMcCall402
FYI in SSM the non breaking space can be entered as "ctrl 0160"
not sure if I understand correctly:
lets say the ML attribute width is 20 character wide
 and the DrawingTitleIsTwenty1 character long and you want DrawingTitle (12 CHARATERS) on the first line and ty1 on the third line. are you say add ctrl 0160 to bake the break?
sheet set palette==> DrawingTitlectrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160IsTwen(4 on second line)ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160ctrl 0160tyi
is that what you meant?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 19 of 33
MMcCall402
First picture this, the title is written in the SSM with normal spaces between the words and the width of the multi-line attribute is small. Each word will be on its own line as the space character will be used as the location to put in an automatic line shift.  Now edit the title in the SSM and replace the normal spaces with non-breaking spaces where you don't want those automatic line shifts to happen.
Mark Mccall
CAD Mangler
Linkedin
Message 20 of 33
Joe-Bouza
Sorry, too advanced for my mind to follow
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
