How to easyly export multiple alignment relationship reports
skaqnxorjs1
skaqnxorjs1
I mainly work with alignment relationship reports.
I want to export multiple alignment relationship reports from one alignment, but civil3d can only export one relational alignment per alignment by default.
If the number of alignment is small, you can manually operate it, but if the number of alignment becomes hundreds, it takes a lot of time. Do you have any good way?
The conditions I want are:
1. Select the main alignment and output other alignments as a report at the same time
2. Station increment is 25, include geometry point is unchecked
3. Save repot format save as xls as name "alignment name".xls                  ex)건넘선10.xls
lim.wendy
안녕하세요@skaqnxorjs1,
Thanks for reaching out to the forum. I think Dynamo may be able to solve what you're looking for.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
