How to delete Zero value ( Null Value) From surface
surajpanayath
Message 1 of 10
surajpanayath
Hi
How to delete Zero value from surface ,see the image from object viewer for reference
Replies (9)
Message 2 of 10
wfberry
You normally have two choices for this.
1.  Eliminate the cause
2.  In your Surface Properties, you can select to not use elevations below a certain elevation.  Such as below 100.00.
You may need to submit your dwg if you want to know the cause.
Bill
Message 3 of 10
Zoom into your low spots and check the linework.  If an object lists at elevation 0, either elevate or erase it.
Message 4 of 10
wfberry
My opinion is that is not what is happening.  He appears to be modeling a corridor and this is a frequent problem, zooming down to "0" elevation.
Bill
Message 5 of 10
Joe-Bouza
Isolate the layers with break line >> set Front view>> grip all the spikes as turn to a contrast color >> back to top. Adjust
Joe Bouza
Message 6 of 10
surajpanayath
Thank you for reply
I didn't understand , Please explain step by step or send me some sample video link for the same
Message 7 of 10
surajpanayath
Drawing Attached fro your reference,Also I am try to create feature line from same file system getting stuck.I tried in other PC that also getting stuck.
Message 8 of 10
Joe-Bouza
you have one tiny oline contour at zero. you bigger issue is there is somthing  int he sureface definition that is holding a zero.
delete all of the contours>>> type oops>>> clear all the edits>>> readd the contours
Joe Bouza
Message 9 of 10
Jeew-m
Hope this helps.
Thank you
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 10 of 10
Joe-Bouza
Not to diminish the suggestions of others but my preference is to edit the data not the surface. you definition has many deleted lines a few added lines .... very hard to keep track of . explore the build options in the surface properties  you can minimize the extra tin lines here
https://autode.sk/2BXiIoz
Joe Bouza
