How to delete a pipe networking structure from profile view?
I want to delete a structure from profiles of pipe networking and redraw this part in it because it has something wrong and inactive to changes. (Delete, not turn off).
I only know how to turn it off but not sure how to delete it completely. Thanks for the help
Mike.M.Carlson
Hello-
I have had luck just selecting it within the Profile View and deleting it (Delete key on keyboard).  Then select the part in Plan view and on the contextual ribbon and add the part back into the profile view once you make the edits.
I hope this helps.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
Simon_Blain
Be careful when using delete that way, IIRC it will erase the profile structure from ALL your profile views.
civilman1957
the easiest way is to click on the profile view grid, right click and choose profile properties. go to the pipe networks tab. all the pipe networks are listed with pipes and structures in order. scroll down and find the structure by number and uncheck it in the left column. it now is not included in the profile view.
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
