How to create surface or solid to model existing tunnel
samir_rezk
Advisor Advisor
samir_rezk
I am wondering about thoughts to model an existing tunnel, I have 3D Polylines resembling contour data at the ground, side and top elevations of a tunnel; I could possibly get the point cloud for the tunnel as well. I tried creating Civil 3D surfaces from each layer and then extracting solids from one surface bound by the next layer above it but it keeps crashing.
It may be more useful to use AutoCAD modelling tools to create a solid out of the data but I am not sure how to go about doing that - loft command didn't work so well for me!
Any help is greatly appreciated - thanks
Samir Rezk
Technical Support Specialist
neilyj666
i don't know the answer but you won't create a Civil surface from this as there will be overlapping areas but you may be able to create a lower and upper surface and use these
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Jowennl
Hi @samir_rezk,
I would recommend you not to convert this current data to a surface and solid as it should be created from the source model. If this is an existing as-built tunnel then ask the surveyor to give you top surface and bottom surface. You may ask the point cloud and create the surface your self as the last option. The attached sample 3d polyline overlap each other and would be very hard to know if converting this to surface tin is accurate enough.
Anyway, I still did try to convert a portion of this tunnel as an exercise. See attached animated gif and dwg.
Some guide images and comments below:
Data as tin surface feedback.pngData as tin surface feedback.pngConcept of tunnel surface creation.pngConcept of tunnel surface creation.pngPortion by Portion Approach.pngPortion by Portion Approach.pngSurface to Solid.pngSurface to Solid.png
Cheers,
Jowenn
Hi guys! I have a similar problem but my solution was to take the 3D polyline’s and whit help of command LOFT create surface. After that I used a command SMOTH and when it’s finished whit processing data I exploded the geometry and created TRM, but it was divided in upper and lower tunnel surface.
But my problem is how to compere TRM surface of tunnel and point cloud from scanning?? To get a section preview as you can get if you create alignment and then compare 2 or more surfaces and display it in section preview???
p.s I have Recap and I converted a LSA file to a recap…
can someone help me???😞😞🙂
