How to create Spiral type Clothoid in Dynamo for Revit from LandXML
Hello everyone! 🙂
I am struggling on creating clothoid using the data from a landxml if neither of radiusEnd and radiusStart is "INF". I hope someone could help me on this.Spiral from LandXML.PNG
Above image is the sample of my landxml. Usually either of the radiusEnd and radiusStart has "INF" value which I already solved. For this case, both has a value, neither of them has an "INF" which I am struggling. I tried to test to make one of them "INF" but it is not working or the result is bad. The below image is the snippet of the code on how I solved if one of the radius has "INF" value. I got this code here [this is a PDF].
Code if one of the radius has "INF" valueCode if one of the radius has "INF" value
I hope someone can understand this problem of mine.
Thank you in advance 🙂
-Anj
Replies (0)
