How to create an offset of existing groond in the View section?
ali.alavinia4
ali.alavinia4
How is the volume of drainage behind the embankment with a thickness of 20 cm along the cross section and above the existing ground automatically calculated automatically? Stripping Top Soil is not the solution.
hamidatut72
it's easy to do. you need to create the third surface by pasting and then raising/lowering it. then add the pasted surface to your sample line group and add it to your computed material/compute a new one. so now compute the materials with 3 surfaces. adjust the above/below. finally, you end it up.
