I import survey data by LANDXML file (omed1.xml) in civil3D. I have a problem that how to convert the survey points and figures which imported into the drawing to TIN Surface.
Solved by johngordon6189. Go to Solution.
John Mayo
If the xml file does not contains a surface definition. Any command can convert imported survey features to Tin surface?
Once you import the xml file into a drawing, the point objects and linework are then able to be added to a surface definition. You may want to make a specific point group to exclude certain points from the surface, but the points and linework are there in the drawing for you to utilize.
